Автор Тема: 08TV061R3  (Прочитано 306 раз)
08TV061R3
« : 30 Ноября 2023, 01:07:15 »
08TV061R3
KDL-32L4000 BC
Subject IRIS
Caution when Replacing NEX Panel [REVISION 3]
A new panel type (VE) has been introduced for KDL-32L4000, being incompatible to the original one.
1. Identify the panel by TV serial number or panel label.
• TV serial number
TV serial number Panel part number
Original panel VE panel Original panel VE panel
5000001~5120000 5120001~5299999
5300001~5420000 5420001~5599999 1-802-699-14 1-802-802-11
5600001~5730000 5730001~5899999
• Panel label
Description Original panel VE panel
Panel label LTY(Z)320AB01-00x LTY(Z)320AB02-A0x
2. Order the same panel as the one used in the set.
HOWEVER, if the original panel is out of stock, you can order a VE panel instead. In that case, make sure to
use a compatible “Inverter Harness”.
Description For original panel For VE panel
P/N Inverter Harness 9-948-030-19 9-948-030-20
