Автор Тема: 08TV059R5  (Прочитано 220 раз)
08TV059R5
« : 30 Ноября 2023, 00:42:29 »
08TV059R5
KDL-26E4000, KDL-26E4020, KDL-26E4030, KDL-26E4050,
KDL-32E4000, KDL-32E4020, KDL-32E4030, KDL-32E4050,
KDL-40E4000, KDL-40E4020, KDL-40E4030, KDL-40E4050
BC
Subject IRIS
Caution when Replacing EG-1L Panel – E Series [REVISION 5]
A new panel type (VE) has been introduced, being incompatible to the original one.
• Always order the same panel as the one used in the set.
• However, if the original panel is out of stock, you can order a VE panel instead. Since only compatible parts
must be used, also the Inverter Harness, and/or LVDS Harness or IP5 board must be replaced, and an EMI
countermeasure may have to be applied.
1. Identify the panel type by the TV serial number (table below) and/or panel label (page 2 of this TB).
Model
TV serial number Panel part number
Original panel VE panel Original panel VE panel
26E4000
4000001~4001506
/ 1-802-613-11 /
4300001~4305803
9000001~9090001 9100001~9190001
1-802-613-11 1-802-754-11
9300001~9390001 9400001~9490001
26E4020
4000001~4000050
/ 1-802-613-11 /
4300001~4303323
26E4030
4000001~4000030
/ 1-802-613-11 /
4300001~4301479
26E4050
4000001~4000170
/ 1-802-613-11 /
4300001~4301646
32E4000
4000001~4001640 4100001~4190001 1-802-648-11
1-802-648-12
1-802-801-11
4300001~4315492 4400001~4490001
32E4020
/ 4000001~4090001 /
4300001~4306346 4400001~4490001 1-802-648-11
1-802-648-12
32E4030
4000001~4000103 4100001~4190001
1-802-648-11
1-802-648-12
4300001~4302065 4400001~4490001
32E4050
4000001~4000344 4100001~4190001
4300001~4303969 4400001~4490001
40E40x0
4000001~4090001 4100001~4190001 1-802-664-11
1-802-664-12
1-802-664-13
1-802-7
