Автор Тема: 08TV087R7  (Прочитано 328 раз)
08TV087R7
« : 30 Ноября 2023, 00:40:55 »
08TV087R7
SE-2AG Chassis BC
Subject IRIS
Software Packages Follow-Up for SE-2AG Chassis [REVISION 7]
The latest software package #036 is valid for all SE-2AG models. Installing is needed after replacing the BC1 board
and to solve the issues mentioned below.
Issue IRIS
code Rev.
TXT subtitles (NL) 137E R2
Timer ON problem (Russia) 1174 R2
VHF channel table (Italy) C26X R2
Turkish menu translation (Turkey) 1731 R2
Cam lock-up during fast Prog+ (SMIT CAM, You see)
* Problem related to the “YouSee” cable network in Denmark. 1311 R3
Audio description problem
* When selecting the Audio Description option for visually impaired, Netherland audio appears
instead of the correct audio.
1286 R3
White screen when disconnecting the Y signal (only 37”)
* When using a DVD connected to the TV set when the DVD player is switched off,
the picture gets frozen and the screen becomes white.
1311 R3
DVB-C missing services at quick or full scan (Finland)
* Not all services are found at quick scan or full scan. Usually frequencies below 200 Mhz
are skipped.
1262 R3
DVB-C missing mux
* Several digital services are missing after doing a quick scan in DVB-C
(Numéricable” network France).
1726 R3
Missing subtitles for hearing impaired (Denmark)
* No subtitles displayed when the option for hearing impaired is selected.
The basic subtitles option works fine.
1721 R3
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching
“Dyrup-Sanderum Antenneforening”.
C34A R5
DVB-T issue (Denmark / Sweden)
* The TV skips regional services in Denmark (TV2) due to broadcast changes.
=> 1. TV2 channel incorrectly stored (Second MUX) – Weaker signal.
=> 2. TV2 is located in multiple channel locations but picture not available.
1727 R5
Noisy picture in analogue when powering on after disconnecting the AC
08TV087 - Software Packages Follow-Up for SE-2AG Chassis [REVISION 7]
