Автор Тема: 08TV064R6  (Прочитано 293 раз)
08TV064R6
« : 30 Ноября 2023, 00:21:23 »
08TV064R6
PROACTIVE / REACTIVE 2 BC
Models
EG-1L100Hz Chassis
Subject: Software Packages Follow-Up for EG-1L100Hz Chassis [REVISION 6]
The latest software package #1.032 is valid for the EG-1L100Hz chassis, and remedies the issues below.
Issue TB Rev.
Translation and Label Errors 08TV068 R0
IRIS code Rev.
VHF channel table (Italy) C26X
R1
Riks TV LCN support (Norway) /
HD forum requirement (France) /
Audio mute after regional switching (Austria) C575
PC input unavailable after AV skip C179
Lost DVB-C channel (Germany) C22A
DVB-T issue (Denmark)
* TV2 channel incorrectly stored (Second MUX) – Weaker signal.
* TV2 located in multiple channel locations, but picture not available.
1727
R2
Audio description problem (NL)
* Yle is using Netherland audio type when sending audio for visually impaired.
When selecting the “Audio Description” option, Netherland audio undesirably appears.
1286
Services from MUX A incorrectly allocated (UK)
* After auto tuning the DVB-T services from MUX A (BBC) are allocated in positions
LCN 800 and higher.
C262
Best mux selection (Finland)
* Final improvements included as from PKG1029. 1727
TV hangs up with SimulHD (Austria) 135A
DVB-C missing mux (Numéricable network, France) 1726
Distorted Audio on Nova TV
* Audio distortion occurs in Mono movies (Old feature movies) after changing from stereo audio
(previous program or advertisement).
C532 R3
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching “Dyrup-Sanderum Antenneforening”. C34A R4
DVB-C TV with Irdeto CAM cannot display Cyrillic characters in messages (Ukraine) K731
R5
Extended info for scheduled events missing in the EPG (Hungary / Czech Republic)
* For certain Hungarian and Czech DVB-T operators, no detailed explanation of a specific TV
programme is given when clicking the short event description.
C286
TV hangs up (memory size exceeded) when containing Cyrillic and Greek characters on events
information D723
Incorrect picture aspect ratio ('16:9' instead of '4:3') for DVB-T services (Hungary) D336
08TV064 - Software Packages Follow-Up for EG-1L100Hz Chassis [REVISION 6]
