Автор Тема: 08TV058R7  (Прочитано 282 раз)
08TV058R7
« : 30 Ноября 2023, 00:17:19 »
08TV058R7
KDL-40L4000, KDL-40S4000, KDL-40S4010, KDL-40U4000,
KDL-40V4000, KDL-40V4210, KDL-40V4220, KDL-40V4230,
KDL-40V4240, KDL-46V4000, KDL-46V4210
BC
Subject IRIS
Caution when Replacing EG-1LL Panel [REVISION 7]
A new panel type (VE) has been introduced, being incompatible to the original one.
• Always order the same panel as the one used in the set.
• However, if the original panel is out of stock, you can order a VE panel instead. In that case, make sure also to
exchange the IP5 board, and apply an EMI countermeasure.
1. Identify the panel type by the TV serial number and/or panel label. Refer to the figure on the next page for the
location of the panel label name.
Model
TV serial number Panel part number + label
Original panel VE panel Original panel VE panel
KDL-40L4000 3000001~3008700
9000001~9090001
9300001~9390001
9600001~9690001
1-802-652-11
1-802-652-12
1-802-652-13
xLTY[Z]400HA06-xxxx
1-802-799-22
xLTZ400HA07-A0xx
KDL-40S4000
KDL-40U4000
4000001~4090001
4300001~4390001
4600001~4690001
4100001~4190001
4400001~4490001
4700001~4790001
KDL-40S4010 4300001~4390001
4400001~4490001
KDL-40V4210 4300001~4304370
KDL-40V4220 4300001~4303213
KDL-40V4230 4300001~4304420
KDL-40V4240 4300001~4307076
KDL-40V4000
3000001~3002934
4000001~4032360
4300001~4318658
4600001~4608566
3100001~3190001
4100001~4190001
4400001~4490001
4700001~4790001
1-802-652-11
1-802-652-12
1-802-652-13
xLTY[Z]400HA06-xxxx
1-802-799-22
xLTZ400HA07-A0xx
1-802-800-11
xLTY400HA11-xxxx
KDL-46V4000
3000001~3090001
4000001~4005462
4300001~4312399
4600001~4607223
3100001~3190001
4100001~4190001
4400001~4490001
4700001~4790001
1-802-650-11
1-802-650-12
1-802-650-14
xLTY[Z]460HB08-xxxx
1-802-798-11
1-802-830-11
xLTY460HB10-00xx KDL-46V4210 4300001~4390001 4400001~4490001
NOTE: the VE panels 1-802-799-22 and 1-802-800-11 on the one hand, and 1-802-798-11 and 1-802-830-11 on
