Автор Тема: 08TV055R1  (Прочитано 180 раз)
08TV055R1
« : 30 Ноября 2023, 00:13:27 »
08TV055R1
WAX-3F Chassis BC
Subject IRIS
White Horizontal Lines [REVISION 1] F330
With AV2 signal input, small white horizontal lines may randomly appear in the screen.
CAUSE
OSD dust in DDR chip due to a data error in the DDR Ram memory.
• Install the latest software package as explained in Technical Bulletin 07TV050, using the software attached to
Technical Bulletin 08TV017.
• In case of a 40 inch panel, first refer to TB 07TV099 to determine whether the set has an AUO or S-LCD panel
mounted.
