Автор Тема: 08TV042R1  (Прочитано 190 раз)
08TV042R1
« : 30 Ноября 2023, 00:11:13 »
08TV042R1
WAX-2FLC BC
Subject IRIS
Caution when Replacing Panel [REVISION 1]
The panel part numbers have changed. If replacing the panel, make sure that the proper software version is
installed.
CAUSE
Change of internal part supplier.
• Whenever replacing, use the same panel as long as it is available in repair stock.
• If the original panel is no longer available, use the other type, updating with the appropriate software after panel
replacement.
1. Panel identification
The information below helps to distinguish a new from an old panel.
OLD NEW
Panel Model name Part number Model name Part number
KDL-40T3500
KDL-40V2900
LTY400HSLH3
1-802-184-11
1-802-184-12
1-802-184-13
1-802-184-21
1-802-184-22
1-802-184-23
1-802-184-33
LTZ400HA03
1-802-553-12
1-802-553-13
KDL-46T3500 LTY460HSLH3
1-802-183-11
1-802-183-12
1-802-183-21
1-802-183-22
LTZ460HA04
1-802-552-11
1-802-552-12
