Автор Тема: 08TV043R6  (Прочитано 317 раз)
08TV043R6
« : 30 Ноября 2023, 00:08:51 »
08TV043R6
REACTIVE 2 TD
Models
EG-1LL Chassis
Subject: Software Packages Follow-up for EG-1LL Gaudi Models [REVISION 6]
The latest software package #118 is valid for all EG-1LL Gaudi models, and remedies the following problems.
Issue IRIS
code
DVB-T issue (Denmark)
* TV2 channel incorrectly stored (Second MUX) – Weaker signal.
* TV2 located in multiple channel locations, but picture not available.
1727
CEC not working with STBx
* When STB is connected to the TV via HDMI, STB is disturbing
CEC communication among other products. As a result, the CEC function on the TV
does not work at all.
2716
Best mux issue, Finland
* Some muxes are not tuned or stored in the memory. 1727
DVB-C missing mux
* Several digital services are missing after doing a quick scan in DVB-C
(in the “Numéricable” network in France).
1726
Timer impossible to set on via Menu 1728
Missing subtitles for hearing impaired (Denmark)
* No subtitles displayed when the option for hearing impaired is selected. The basic subtitles option
works fine.
1721
Audio description problem
* When selecting the Audio Description option for visually impaired, Netherland audio appears instead
of the correct audio.
1286
Digital block noise (France) C342
Parental rating (Salzburg) 117L
VHF channel table (Italy) C26X
TB
New VE panel introduction 08TV056
procedure for software fixes outlined below.
NOTE: For the full upgrade procedure (panel and board exchange), please refer to TB 08TV030.
1. If the installed SW version is v1.15 or lower, start by updating the “Digital Launcher” to version #0.79.21.
2. Write the Main, Verd, and Digital micro to the latest version.
3. If applicable, write the NVM software to the latest version.
Date Software package Attachment Data
June 2009
0.79.21 memorystick_eg1l_l_int_36.zip Digital Launcher (DM2.26.36)
#118 eg1ll_gaudi_pkg_118_memorystick.zip
Main micro (TM1.17)
Verd micro (S1.130E)
Digital micro (DM2.26.36)
Only if replacing from
old to new VE panel eg1ll_gaudi_pkg_117_memorystick_nvm.zip NVM
 The table below lists the NVM files to be used for each specific model, depending on the panel type. The way
to determine whether the update concerns an original panel or a VE panel, is explained in TB 08TV056.
Model
NVM files
Original panel New VE panel
KDL-40L40xx gaudi_40_l.eep gaudi_40_l_np.eep
KDL-40S40xx gaudi_40_bm.eep gaudi_40_bm_np.eep
KDL-40U40xx gaudi_40_bml.eep gaudi_40_bml_np.eep
KDL-40V4xxx gaudi_40_nw.eep gaudi_40_nw_np.eep
KDL-46V4xxx gaudi_46_nw.eep gaudi_46_nw_np.eep
KDL-52Vxxxx gaudi_52_nw.eep gaudi_52_nw_np.eep
08TV043 - Software Packages Follow-up for EG-1LL Gaudi Models [REVISION 6]
