Автор Тема: 08TV039R1  (Прочитано 374 раз)
08TV039R1
« : 29 Ноября 2023, 23:47:12 »
08TV039R1
KDL-46V2500 BC
Subject IRIS
Caution Note on Panel Compatibility [REVISION 1]
A new LCD panel type (WCG3) has been introduced, in addition to the existing WCG1 panel.
CAUSE
Different lamp at LCD panel backside.
• Whenever replacing, use the same panel type as long as it is available in repair stock.
• If the original panel type is no longer available, the other type can be used. In that case, make sure to update
with the appropriate software, following the guidelines below.
1. WCG1 – WCG3 panel distinction
Use the information below to identify the panel type.
1-1. Serial number
Destination WCG1 serial number WCG3 serial number
Continental Europe / 4300001~
UK / 4000001~
1-2. Vendor type name
