Автор Тема: 08TV038R18  (Прочитано 332 раз)
08TV038R18
« : 29 Ноября 2023, 23:45:37 »
08TV038R18
PROACTIVE / REACTIVE 2 BC
Models
EG-1L Chassis
Subject: Software Packages Follow-Up for EG-1L Chassis [REVISION 18]
The latest software package #413 is valid for the EG-1L chassis, and remedies the problems below.
IMPORTANT: In case of CEC problems (“Intermittent Bravia Theatre Sync Operation”), do not update to the latest
software version, but refer to TB 09TV055 for further details and the older software file to be used.
Issue TB Rev.
OSIM functionality 08TV088 R6
New VE panel introduction 08TV057 R3
IRIS code
Digital Block noise (France) C342 R3
Double program change in digital (General) 178X R5
Smit CAM issue (Denmark) C272 R5
Duplicate Mux (DVB-C, DVB-T) 121A R5
Order of digital services reset (Germany) C28X R5
Audio mute after regional switching (Austria) C575 R6
TV tunes wrong multiplex (Best mux issue, Finland) 1727 R6
CEC hang-up with STB (Holland) K785 R6
VHF channel table (Italy) C26X R6
French HD LCN support (France) / R6
MediaSet Certification (Italy) / R9
DVB-C missing mux (Numéricable network, France) 1726 R10
Timer cannot be set on in menu 1728 R10
Missing subtitles for hearing impaired (Denmark) 1721 R10
Audio description problem 1286 R10
No audio on TV HD Nova
* After about 2 hours of working on “TV Nova HD” the audio is somehow blocked and
no sound is audible. If switching TV channels, also these channels are without sound.
3228 R11
DVB-T issue (Denmark)
* TV2 channel incorrectly stored (Second MUX) – Weaker signal.
* TV2 located in multiple channel locations, but picture not available.
08TV038 - Software Packages Follow-Up for EG-1L Chassis [REVISION 18]
