Автор Тема: 08TV028R2  (Прочитано 299 раз)
08TV028R2
« : 29 Ноября 2023, 23:32:54 »
08TV028R2
SE-2H Chassis BC
Subject IRIS
Software Packages Follow-Up for SE-2H Chassis [REVISION 2]
The latest software package #013 is valid for all SE-2 Hotel models.
Install the latest software package #013 using the files attached to this document and following the abridged
procedure for software fixes outlined below.
Date Software package Attachment Files
February 2010 #013 SE2H_HO_pkg_013_ms.zip
VM 4.13 (VCTP micro)
DM 2.18.10 (Digital micro)
 For the full upgrade procedure (panel and board exchange), please refer to TB 08TV013.
 Refer to the table below to identify the applicable NVM file. For 37 inch models, first check TB 08TV024.
Date Model Series Panel NVM Attachment
July 2008
KDL-37P300H
KDL-37P302H
P30xH_37”
1-802-524-13
T370XW02.V5 SE2_HO_nvm_P30xH_37.zip
P30xH_37”
(Dif. panel)
1-802-524-21
T370XW02.V508
SE2_HO_nvm_P30xH_37_dp.zip
KDL-40P300H
KDL-40P302H P30xH_40” / SE2_HO_nvm_P30xH_40.zip
Update procedure
1. Copy the attached “SE2H_HO_pkg_xxx_ms.zip” file to an empty Memory Stick and unzip it.
2. Switch off the TV using the [Power] key, and insert the MS. Do NOT use the remote commander [Standby] key!
3. Switch on the TV using the [Power] key.
4. The “Digital Micro” data will be updated. No download message appears.
5. When finished, the “TV Micro” update will start. An “Update Start” message appears on the screen.
6. After a few seconds the “Update Start” message disappears and the update process starts.
7. During the MS download, the left amber [Timer] LED will blink, while the centre [Standby] LED is red and fix.
8. When the update process has finished, the TV set will power on.
9. After a few seconds, the “Update Complete” message appears.
10. Switch off the TV and remove the Memory Stick.
11. Power on the TV.
12. Apply “TT08” (recommended but not obligatory).
08TV028 - Software Packages Follow-Up for SE-2H Chassis [REVISION 2]
