Автор Тема: 08TV025R8  (Прочитано 420 раз)
08TV025R8
« : 29 Ноября 2023, 23:12:37 »
08TV025R8
REACTIVE 2 TD
Models
EG-1L Chassis
Subject: Software Upgrade Procedure for EG-1L Chassis [REVISION 8]
This Technical Bulletin describes the software upgrading procedure for the EG-1L chassis, using a Memory Stick.
Amongst others, the latest software version is needed when exchanging the BE1 board, which requires an update
of the MS DL Digital, VCTP, NVM VCTP & Verd data.
 An alternative update (cf. “4. Alternative update (when no LED activity)”) may be needed. In that case, use the
“MS_Reset_PKG_EG1L.zip” file attached to this Technical Bulletin.
 In case of replacing from an original to a VE panel (refer to TB 08TV057 to identify the panel type), carry out an
additional NVM update (cf. step “5. NVM update”).
! CAUTION !
 Only use the attachment file “MS_Reset_PKG_EG1L.zip” in case a regular update fails.
 Whenever exchanging the B1 board, make sure to transfer the shield from the old board to the new board.
In case of loss, new parts can be ordered with the info in the table.
Ref. Description Part number
1 Shield 3-878-550-01
2 Screw (HEX) VGA 4-635-966-01
3 Screw Fixing Shield to Board 2-580-628-01
08TV025 - Software Upgrade Procedure for EG-1L Chassis [REVISION 8]
