Автор Тема: 08TV024R5  (Прочитано 179 раз)
08TV024R5
« : 29 Ноября 2023, 23:10:13 »
08TV024R5
KDL-37P3000, KDL-37P300H, KDL-37P3010, KDL-37P3020,
KDL-37P302H, KDL-37P3030, KDL-37U3000
BC
Subject IRIS
Caution when Exchanging 37 Inch Panel [REVISION 5]
The 37 inch panel for the SE-2 chassis has been replaced by a new standard panel being not directly compatible
with its predecessor.
• It is recommended to replace the panel with an original type. However, if this is not possible, use the guidelines
below.
• In case of a panel exchange, it is necessary to check the parts mentioned below, and correct the NVM file
depending on the serial number range. Use the serial number list at the end of this Technical Bulletin to define
which parts are to be used for which model.
1. Power supply (GS3)
Description Part number Note
OLD GS3 Compl Kit (STT) A-1359-005-A Only compatible with
panel P/N 1-802-524-12 or -13
NEW GS3 Compl Kit (STT) A-1531-926-A Compatible with all panel P/Ns
When the GS3 board requires replacing, it is recommended to upgrade to the new part number.
2. Panel and cable
Description Part number Label
OLD
LCD Panel (37inch WXGA TFT) 1-802-524-12/13
T370XW02V5
Inverter Board 1-789-962-11 1926006361
37” Inverter Cable 1-910-040-44 /
NEW
LCD Panel (37inch WXGA TFT) 1-802-524-21
AU37X25ACCTW6TW186KW5EV
Inverter Board 1-789-962-21 1926006179
14P Inverter Connector Assy 1-910-048-26 /
• NOTE: Panel, Inverter board and cable must be compatible!
• Refer to the pictures on the next page to differentiate the old panel and cable from the new ones.
