Автор Тема: 08TV023R7  (Прочитано 296 раз)
08TV023R7
« : 29 Ноября 2023, 23:08:46 »
08TV023R7
FIX, FIX2, SE1, SE-1A, SE-1T, SE2, SE-2AG, SE-2H, WAX2, WAX-2F,
WAX-2FLC, WAX-2T, WAX-3F, WAX-3H Chassis
TD
Subject IRIS
Serial Number / Model Name Writing Support [REVISION 7] 1721
No serial number and model name after board exchange.
CAUSE
Generic serial number for service.
Write the applicable serial number to the NVM. The serial number address in the NVM consists of 4, 8 or 10 bytes
in hexadecimal format depending on the chassis.
Chassis Bytes
SE1, SE-1A, SE-1T, SE2, SE-2AG, SE-2H 4
FIX, FIX2 8
WAX2, WAX-2F, WAX-2FLC, WAX-2T, WAX-3F, WAX-3H 10
1. Run the "CODE2.EXE" file attached to this Technical Bulletin.
2. Make sure that the COM port baud rate is set to the value below, depending on the chassis.
Chassis Baud rate
SE1, SE-1A, SE-1T, SE2, SE-2AG, SE-2H, WAX2, WAX-2F, WAX-2FLC, WAX-2T 38400
FIX, FIX2 9600
WAX-3F, WAX-3H 115200
3. Open the "Analyzer" window ([MENU] => [TOOLS] => [ANALYZER]).
4. Calculate the ECS command via OPTION 1 or OPTION 2.
5. Check the [Add Check Sum] box.
08TV023 - Serial Number  Model Name Writing Support [REVISION 7] - FIXx , SEx , WAXx , etc
