Автор Тема: 08TV020R3  (Прочитано 326 раз)
08TV020R3
« : 29 Ноября 2023, 23:04:28 »
08TV020R3
KDL-20S2000, KDL-20S2020, KDL-20S2030, KDL-20S4000,
KDL-20S4020, KDL-26U2000, KDL-32U2000, KDL-40U2000
BC
Subject IRIS
Software Packages Follow-Up for SE1 Chassis [REVISION 3]
The latest software packages #064 and #064b are valid for the SE1 chassis and solve the problems explained in
Technical Bulletin 06TV126 and below. If updating is necessary, use the correct version depending on the serial
number in list A or list B (page 3).
Issue – ANALOG IRIS code
DVB-T Issue (Denmark)
* TV skips regional services in Denmark (TV2) due to broadcast changes.
1. TV2 channel is incorrectly stored (Second MUX) – Weaker signal.
2. TV2 is located in multiple channel locations but picture not available.
1727
No audio on EPG and SmartLink recordings 1510
Horizontal jitter in VCR signals (AV connections or RF) F353
Malfunction in 1080i and 720p formats on Component input D350
Russian language errors 1731
OSD change (see serial number lists) /
HDMI for Russian HDCP /
Standby C+ France 117H
Weekly timers (wake-up timer for Monday to Friday weekly update) 1174
Issue – DIGITAL
Czech CT2 program problem C22A
Install the latest software packages #064 or #064b using the files attached to this document and following the
abridged procedure for software fixes on the next page.
NOTE: For the full upgrade procedure (panel and board exchange), please refer to TB 06TV127.
Date Software
Package Attachments Files Serial
number
December 2010
#064b
SE1_VCTP_2464_v2.zip VM 24.64 (Main micro)
List A
memorystick_wax2m_int_515_00.zip DM 2.5.515 (Digital micro)
#064
List B
memorystick_wax2p_mheg_int_602.zip DM 2.15.602 (Digital micro)
CAUTION
 Make sure to update the software and the NVM data from the same software package.
 The procedure for checking the NVM file is explained in TB 06TV146.
Condition
code
Symptom
code
Part
number Ref. Section
