Автор Тема: 08TV018  (Прочитано 189 раз)
08TV018
« : 29 Ноября 2023, 23:01:24 »
08TV018
WAX-3F Chassis BC
Subject IRIS
Red Dot Noise 4342
Red dot noise may be visible in “1080p picture”. The affected signals are:
• HDMI 1080p_50Hz/60Hz.
• 1080_24p.
• Comp_1080p_50Hz/60Hz.
CAUSE
Too high room temperature.
• Over 30 °C → 10 percent of the sets likely to reproduce the phenomenon.
• Over 40 °C → 90 percent of the sets likely to reproduce the phenomenon.
In order to change the ”Trident clock data” as indicated in the table below, install the latest software package
PKG1.019 using the attachment to Technical Bulletin 08TV017.
