Автор Тема: 08TV014R2  (Прочитано 175 раз)
08TV014R2
« : 29 Ноября 2023, 22:58:08 »
08TV014R2
FIX2 Chassis TD
Subject IRIS
AE, FB2 and AVC Board Replacement [REVISION 2]
The procedure for replacing the AE, FB2 and AVC board is outlined below.
Follow the guidelines to replace each of the three boards. Refer to the attachments to Technical Bulletin 07TV085
for the correct MS update software to be installed.
1. AE Board Replacement
1-1. Settings Change
1-1-1. Enter the service mode using the remote commander.
1-1-2. The TVM menu below appears.
