Автор Тема: 08TV012R3  (Прочитано 181 раз)
08TV012R3
« : 29 Ноября 2023, 22:56:55 »
08TV012R3
KDL-40D3400, KDL-40D3500, KDL-40D3550, KDL-40D3660,
KDL-40V3000, KDL-46D3400, KDL-46D3500, KDL-46D3550,
KDL-46D3660, KDL-46V3000
TD
Subject IRIS
BE1F Board Exchange [REVISION 3]
A new BE1F board has been introduced, requiring an update of the TVM, NVM and Digital data.
• Upgrade with the latest software package(s), using the attachments to Technical Bulletin 08TV017, and
following the procedure outlined below. Use the letters A, B and C in the table below to determine the precise
package to be installed.
• In case of a 40 inch model, refer to Technical Bulletin 07TV099 to determine whether the set has an AUO or SLCD
panel.
• Verify step 3-7 of this Technical Bulletin to see whether on top of the regular update file also the alternative
update file has to be used.
Model Model Type Series
BE1F board part number Software
OLD NEW package
KDL-40V3000 4 V 40” A-1443-030-A
A-1443-030-E A
KDL-46V3000 5 V 46” A-1443-166-A
KDL-40D3400
KDL-40D3500
6
LC 40” DB
Panel AUO
A-1487-857-A A-1487-856-A B
KDL-46D3400
KDL-46D3500
7
LC 46” DB
Panel AUO
KDL-40D3550
KDL-40D3660
8
LC 40” DF
Panel AUO
KDL-46D3550
KDL-46D3660
9
LC 46” DF
Panel AUO
KDL-40D3400
KDL-40D3500
12
LC SLCD 40” DB
Panel SLCD
/ A-1506-864-A C KDL-40D3550
KDL-40D3660
14
LC SLCD 40” DF
Panel SLCD
