Автор Тема: 08TV010R1  (Прочитано 167 раз)
08TV010R1
« : 29 Ноября 2023, 22:55:50 »
08TV010R1
KDL-40W3000, KDL-40X3000, KDL-40X3500, KDL-46W3000,
KDL-46X3000, KDL-46X3500, KDL-52W3000, KDL-52X3500,
KDL-70X3500
BC
Subject IRIS
Deletion of Favourite List 2, 3 and 4 [REVISION 1] 1717
• In countries which use “order fond sorting” the “Favourite Lists” 2, 3 and 4 may be deleted when the TV is in
standby.
• All European countries, except those listed below, are affected. The non-affected countries use “LCN sorting”.
Countries NOT affected
Denmark DTT – Finland - France DTT - Netherlands DTT - Norway DTT – Sweden - UK DTT
CAUSE
Software bug, causing a network setting change.
If the problem occurs, update the Emma software to version 2.14.583 or higher, referring to Technical Bulletin
07TV086R* for the software upgrading procedure and the attachment to Technical Bulletin 07TV085R* for the
latest software package.
APPLICABLE SERIAL NUMBERS
Model Serial number
KDL-40W3000
~4007853
~4341720
KDL-40X3000
~4602591
~4804471
KDL-40X3500
~4002358
~4318648
KDL-46W3000
~4002445
~4310818
KDL-46X3000
~4601261
~4802446
KDL-46X3500
~4001632
~4307454
KDL-52W3000
~4100225
~4401812
KDL-52X3500
~4100151
~4401230
KDL-70X3500 ~7000199
Flag Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
1 717 08TV010 SFT 1 2 1 FIX2
