Автор Тема: 08TV017R7  (Прочитано 309 раз)
08TV017R7
« : 29 Ноября 2023, 22:53:03 »
08TV017R7
WAX-3F Chassis BC
Subject IRIS
Software Packages Follow-Up for WAX-3F Chassis [REVISION 7]
The latest software packages are valid for the WAX-3F chassis, and solve the problems below.
Issue TB
Red dot noise 08TV018
DVB-C problems 08TV054
White horizontal lines 08TV055
IRIS code
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching “Dyrup-Sanderum
Antenneforening”.
C34A
CAM lock-up during fast Prog+/- (SMIT CAM, “You see” cable network - Denmark) 6723
EPG Navigation latch-up (Lausanne Citycable provider - Switzerland)
* TV goes to STBY when navigating through EPG. The only way to recover is to switch off/on
by main switch.
C119
DVB-C missing mux (“Numéricable” network France)
* Several digital services are missing after doing a quick scan in DVB-C. D22A
Missing subtitles for hearing impaired (Denmark)
* No subtitles are displayed when the option subtitles for hearing impaired is selected.
No problem with Basic subtitle options.
D286
Audio description problem
* Yle is using Netherland audio type when sending audio for visually impaired.
When selecting “Audio Description”, Netherland audio appears instead of the correct audio.
1286
TV crash when watching DVB-T (UK)
* The TV set periodically crashes and reboots when watching MUX A (e.g. Channel 5). C722
DVB-T issue (Denmark): TV2 always stored in channel space nr. 4.
* TV2 channel region at room no. 4 is not the same as before the change.
* TV2 located in multiple channel locations, but cannot be displayed.
