Автор Тема: 08TV013R7  (Прочитано 306 раз)
08TV013R7
« : 29 Ноября 2023, 22:51:07 »
08TV013R7
SE-2(H) Chassis BC
Subject IRIS
Software / Board Upgrade Procedure for SE-2(H) Chassis [REVISION 7]
This Technical Bulletin describes the software upgrading procedure for the SE-2(H) chassis. An update may be
needed after replacing the panel or B1 / B2 Board, or in case of software fixes.
Model Old part number New part number
KLV-20G30xx A-1368-033-A A-1563-481-A
KDL-20B40xx, -20S30xx A-1334-484-A A-1563-482-A
KDL-23B40xx A-1517-426-A A-1563-483-A
KDL-26B40xx / A-1498-638-A
KDL-26S28x0, -26S30x0, -26T28xx,
-26P30x0, -26U30xx A-1454-412-A A-1498-637-A
KDL-26T26xH, -26P30xH A-1486-565-A A-1563-485-A
KDL-32P30xH A-1486-566-A A-1563-484-A
KDL-32P30x0, -32U30xx A-1336-696-A A-1498-638-A
KDL-37P30x0, -37U30xx A-1336-697-A A-1498-639-A
KDL-37P30x0, -37U30xx (Dif. panel) A-1336-697-A A-1555-343-A
KDL-37P3xxH A-1486-567-A A-1544-166-A
KDL-37P3xxH (Dif. panel) A-1486-567-A A-1555-344-A
KDL-40P30xH A-1486-568-A A-1544-167-A
KDL-40P30x0, -40U30x0 A-1382-602-A A-1498-640-A
• It is vital to transfer to original NVM data from the old to the new board.
• In all cases, check the HDMI and PC input.
• Notice that two alternative procedures exist.
CAUTION
For KDL-37P3000-10-20-30, -37U3000, -37P300H and -37P302H, refer to TB 08TV024 to check the panel type.
UPDATE PROCEDURE
1. Memory Stick formatting
• Format your Memory Stick using a Memory Stick formatter. A special program can be downloaded from:
http://support.sony-europe.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM#disc.
• Windows formatters are not supported.
2. TVM & Digital Micro update
2-1. Choose the appropriate “se2_pkg_xxx_ms.zip” file attached to Technical Bulletin 08TV006 (Domestic) or
08TV028 (Hotel). Copy it to the empty Memory Stick and unzip it.
2-2. Switch off the TV using the [Power] key, and insert the Memory Stick. Do NOT use the [Standby]
