Автор Тема: 08TV009  (Прочитано 199 раз)
08TV009
« : 29 Ноября 2023, 22:47:25 »
08TV009
KDL-37P3000, KDL-37P3020, KDL-37P3030, KDL-40D2600,
KDL-40D2710, KDL-40D2810, KDL-40D3000, KDL-40D3010,
KDL-40D3400, KDL-40D3500, KDL-40D3550, KDL-40D3660,
KDL-40P3000, KDL-40P3020, KDL-40P3030, KDL-40S3000,
KDL-40S3010, KDL-40U3000, KDL-40V3000, KDL-40W3000,
KDL-40X3000, KDL-40X3500, KDL-46D3000, KDL-46D3010,
KDL-46D3400, KDL-46D3500, KDL-46D3550, KDL-46D3660
KDL-46V3000, KDL-46W3000, KDL-46X3000, KDL-46X3500,
KDL-52W3000, KDL-52X3500
BC
Subject IRIS
TV Switching On/Off or No Power 1110
The set may intermittently power off or on, or be impossible to power on, with 2 LEDs blinking.
CAUSE
• Bad contact between the connector and core of the power relay. The core is deformed due to the
incompatibility of two internal parts.
• The diagram below illustrates the problem.
* OK = the “Move contact” pushes the “Fixed contact”, making the latter bend.
* Not OK = the “Move contact” pushes the “Fixed contact”, without making the latter bend due to the “Fixed
contact” being 0.2mm more curved outside than allowed
