Автор Тема: 08TV003R1  (Прочитано 202 раз)
08TV003R1
« : 29 Ноября 2023, 22:43:58 »
08TV003R1
KDL-37P3000, KDL-37P300H, KDL-37P302H, KDL-37P3020 BC
Subject IRIS
No Power On / Defective GS3 Board [REVISION 1]
The set may be impossible to power on.
CAUSE
Broken GS3 board around the VESA Support, caused by excessive stress applied to the VESA Support during
transportation of the set outside the original carton from dealer to customer, or customer to service.
1. If the symptom occurs, confirm the GS3 Board condition.
• If damaged, replace the GS3 board, and continue with the procedure below.
• If not damaged, do not replace the GS3 board, and continue with the procedure below.
2. Permanently remove the VESA Support.
