Автор Тема: 08TV008R1  (Прочитано 365 раз)
08TV008R1
« : 29 Ноября 2023, 22:42:46 »
08TV008R1
SE-1A Chassis BC
Subject IRIS
BC Board Exchange [REVISION 1]
New BC boards have been introduced, requiring a software upgrade of the “TVM & Digital” and “NVM” data.
1. TVM & Digital Upgrade
Refer to Technical Bulletin 07TV094R* for the “TVM & Digital” upgrade procedure.
2. NVM Upgrade
* Refer to the table below to determine the exact zip file to be used per model. Unzip this update file into an empty
memory stick. A folder “wax3” will be created, even though the software is for the SE-1A chassis.
* Repeat step 2-2 to 2-10 of 07TV094R*, using the software for the NVM data.
* Make sure to only update the NVM data after having updated the TVM and Digital data, otherwise the NVM data
writing will not be correct.
Date BC board part number Model NVM software package
KDL-32D2600
KDL-32D2710
KDL-32D2810
SE1A_044b_nvm_D2xxx_32.zip
KDL-32S3000
KDL-32S3010
KDL-32S3020
SE1A_044b_nvm_S30xx_32.zip
KDL-32T2800
KDL-32T3000
SE1A_044b_nvm_T30_28xx_32.zip
KDL-40D2600
KDL-40D2710
KDL-40D2810
SE1A_044b_nvm_D2xxx_40.zip
KDL-40S3000
KDL-40S3010
SE1A_044b_nvm_S30xx_40.zip
A-1503-611-A
KDL-40T2800
KDL-40T3000
SE1A_044b_nvm_T30_28xx_40.zip
KDL-32T2600 SE1A_044b_nvm_T26xx_32.zip
A-1503-610-A
KDL-32S2800 SE1A_044b_nvm_S28xx_32.zip
January 2008
A-1503-609-A KDL-26T3000 SE1A_044b_nvm_T30xx_26.zip
08TV008 - SE-1A - BC Board Exchange [REVISION 1]
