Автор Тема: 07TV094R8  (Прочитано 207 раз)
07TV094R8
« : 29 Ноября 2023, 19:44:00 »
07TV094R8
SE-1A Chassis BC
Subject IRIS
Software Upgrading Procedure for SE-1A Chassis [REVISION 8]
The software upgrading procedure for the SE-1A chassis models is indicated below.
1. Memory Stick formatting
All micros can be updated via Memory Stick. All MS formats (Normal, Pro) are accepted, but compatibility problems
could arise with some types or size.
 Remove unnecessary files from the Micro Stick before copying files.
 Use a memory stick formatter to format. Windows formatters are not supported. A special program can be
downloaded from:
http://support.sony-europe.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM#disc.
 The recommended option is using a digital camera.
2. Update of TVM & Digital data
2-1. Download and unzip the latest SW package attached to Technical Bulletin 07TV093. A folder “wax3” will be
created, even though the software is for a different chassis.
2-2. Copy the whole “wax3” folder to the root of your MS, e.g. “F:\wax3”.
!! 2-3. Make sure that the set is in “Digital RF”.
2-4. Power OFF the set using the [Power] button on the TV. Do not use the remote commander.
2-5. Insert the MS into the slot on the TV back. Be sure to set the printed label of the MS towards the front panel.
2-6. Power on the set by local key, at the top of the set.
2-7.
