Автор Тема: 07TV092R2  (Прочитано 186 раз)
07TV092R2
« : 29 Ноября 2023, 19:42:54 »
07TV092R2
SE-1A Chassis BC
Subject IRIS
DVB-C Problems [REVISION 2]
One of the following DVB-C problems may occur.
Issue IRIS code
1. When using a Technisat CAM, certain encrypted services
may not be descrambled correctly by the TV set. 6723
2. When the DVB-C cable operator does not correctly signal the NIT,
the MUX (service) will be missed during scanning. D22A
3. Incorrect display of the umlauted characters ä, ö, ü. 1731
Symptom 1 and 2
Install the latest software package as explained in Technical Bulletin 07TV094R* using the software attached to
Technical Bulletin 07TV093R*.
Symptom 3
Customers in Austria and Switzerland can switch the country setting to “Germany” to solve the problem. As a
second option, which is only to be used in case of a persistent customer demand, a software update should be
performed. In that case, only an upgrade of the “TVM & Digital” data is necessary.
IMPORTANT
Only report this problem in warranty claim if it is the reason for customer/dealer return. If the software is
updated by routine job, it should not be reported in claim.
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
cf. above
