Автор Тема: 07TV101R6  (Прочитано 336 раз)
07TV101R6
« : 29 Ноября 2023, 18:53:45 »
07TV101R6
KDL-40W3000, KDL-40X3000, KDL-40X3500, KDL-46W3000,
KDL-46X3000, KDL-46X3500, KDL-52W3000, KDL-52X3500
BC
Subject IRIS
Panel Software Compatibility [REVISION 6]
Two different LCD panels exist (Panel T2, 2chip T-CON – Panel T1, 1chip T-CON), each requiring different
software.
Check the tables to match a specific panel with the correct software. Next, consult Technical Bulletin 07TV085R*
for the latest software packages and TB 07TV086 for the upgrade procedure. The picture below may help to locate
and identify the panel label.
T-CON 1CHIP (T1 PANEL)
Type 40 inch – New G7 46 inch – New G7 52 inch – G8
Name LTY400HC01 005 LTY460HH-LH2 003 LTY[Z]520HE03 101
Part number 1-802-489-31 1-802-491-31 1-802-490-32
Model
serial number
KDL-40X3000
4600516~
4801326~
KDL-46X3000
4600845~
4801459~
KDL-52X3500
4100001~
4301843~4301847
4302107~4302124
4400001~
KDL-40X3500
4001428~
4310870~
KDL-46X3500
4001164~
4304052~
Type / 52 inch – G8
Name / LTY[Z]520HB02
Part number / 1-802-593-11
Model
serial number
/ KDL-52W3000
4100001~
4302264-4302268
4302440
4302831-4302847
07TV101 - FIX2 - Panel Software Compatibility [REVISION 6]
