Автор Тема: 07TV093R9  (Прочитано 340 раз)
07TV093R9
« : 29 Ноября 2023, 17:42:29 »
07TV093R9
SE-1A Chassis BC
Subject IRIS
Software Packages Follow-Up for SE-1A Chassis [REVISION 9]
The latest software package #056 is valid for the SE-1A chassis. It remedies the issues mentioned below.
Issue TB Rev.
Technisat CAM
Missing MUX 07TV092 R2
Incorrect characters ä, ö, ü
IRIS code
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching “Dyrup-Sanderum
Antenneforening”.
C34A R8
DVB-T issue (Denmark / Sweden)
* The TV skips regional services in Denmark (TV2) due to broadcast changes.
=> 1. TV2 channel incorrectly stored (Second MUX) – Weaker signal.
=> 2. TV2 is located in multiple channel locations but picture not available.
1727 R8
CAM lock-up during fast Prog+/- (SMIT CAM, “You see” cable network - Denmark) 6723 R6
EPG Navigation latch-up (Lausanne Citycable provider - Switzerland)
* TV goes to STBY when navigating through EPG.
The only way to recover is to switch off/on by main switch.
C119 R6
DVB-C missing mux (“Numéricable” network France)
* Several digital services are missing after doing a quick scan in DVB-C. D22A R6
Missing subtitles for hearing impaired (Denmark)
* No subtitles are displayed when the option subtitles for hearing impaired is selected.
No problem with Basic subtitle options.
D286 R6
Audio description problem
* Yle is using Netherland audio type when sending audio for visually impaired.
When selecting “Audio Description”, Netherland audio appears instead of the correct audio.
1286 R6
TV crash when watching DVB-T (UK)
* The TV set periodically crashes and reboots when watching MUX A (e.g. Channel 5). C722 R6
No TXT subtitles after 15-20 min (Dutch broadcasting) 337E R5
On/Off timer problem 1174 R5
Weekly timers problem
07TV093 - Software Packages Follow-Up for SE-1A Chassis [REVISION 9]
