Автор Тема: 07TV089R1  (Прочитано 238 раз)
07TV089R1
« : 29 Ноября 2023, 17:40:32 »
07TV089R1
KDL-20G2000 BC
Subject IRIS
Caution with Panel Replacement [REVISION 1]
A new panel type has been introduced, being fully compatible with the current one, except for the W/B adjustment
(NVM data).
• Both panels are supported for repair service.
• When replacing, just make sure to install a full update of the applicable NVM files, integrated in the software
packages of Technical Bulletin 07TV015R*.
Description Part number NVM file Label
CLAA201VA07
1-802-271-11
1-802-271-12
SE1_720_20.EEP
CLAA201VA07C 1-802-271-21 SE1_720_20_V07C.EEP
