Автор Тема: 07TV086R2  (Прочитано 206 раз)
07TV086R2
« : 29 Ноября 2023, 17:37:00 »
07TV086R2
KDL-40W3000, KDL-40X3000, KDL-40X3500, KDL-46W3000,
KDL-46X3000, KDL-46X3500, KDL-52W3000, KDL-52X3000,
KDL-52X3500, KDL-70X3500
BC
Subject IRIS
Software Upgrading Procedure [REVISION 2]
This Technical Bulletin describes the software upgrading procedure using a memory stick.
• The DL image can be found by opening the correct attachment to Technical Bulletin 07TV085R*. The
composition of the attachment names is clarified below.
C-xxxxLE_y_zz_T_BCN.ZIP
xxxx 􀂼 Package version (e.g. 5010)
y 􀂼 Model type X (e.g. KDL-40X3500)
or W (e.g. KDL-40W3000)
zz 􀂼 Panel size (e.g. 40)
T 􀂼 Panel Type (T1 or T2)
• Each DL image consists of the software data below. If the upgrading software is up to date, then the upgrading
for the specific program or data will be skipped.
* EMMA (Digital software)
* ASUCA
* KAISER (Main TV micro)
* BEM
* NVMs
NOTES
• The NVM will be updated with the area for adjustment masked (W/B, AD, SN will not be overwritten).
• In case of a troubled upgrading, disconnect and reconnect the AC cable with the memory stick still inserted,
and try to upgrade again.
