Автор Тема: 07TV085R11  (Прочитано 347 раз)
07TV085R11
« : 29 Ноября 2023, 17:31:28 »
07TV085R11
FIX-2 Chassis BC
Subject IRIS
Software Packages Follow-Up for FIX-2 Chassis [REVISION 11]
The latest software packages solve the problems mentioned below.
Issue TB Rev.
HDMI-CEC problems
* If a TV is connected to an AV amplifier with CEC functionality and the output is set to
“Amp.” intermittently, the sound may stop for a few seconds.
* Condition: TV connected to a Panasonic DVD Player or Home Theatre while TV is [ON],
the CEC function is [ON] and the DVD is [OFF]. When operating the [One touch play mode]
of the DVD’s CEC function, the TV will power off, and power on again after 30 seconds. The
DVD player stays powered off. The Home Theatre System is OK.
K780 R0
Canal+ STB Sagem problem France
* When the STB is [ON] while connected via HDMI3 (AV8) picture and powering on the TV,
the screen may blue out, without sound appearing. The STB needs resetting.
F330 R0
No display of special characters in the service name of the digital banner C731 R0
USB Photo Viewer problem
* Pictures taken by -X3000 and -X3500 models are displayed upside-down when not taking
the photo in landscape.
F781 R0
Czech Banner Problems 07TV096 R1
DVB-C Problems 07TV100 R2
Panel Software Compatibility (ALL models, except KDL-70X3500) 07TV101 R2
Fan Noise (ALL models, except KDL-70X3500) 07TV098 R3
Missing Surround Sound Audio on SPDIF Output 08TV005 R3
Deletion of Favourite List 2, 3 and 4 08TV010 R4
Incorrect HD Subtitle Display 08TV019 R6
IRIS code
VHF channel table (Italy)
* Frequency list in the VHF band has been changed in Italy. Therefore, the frequency table
has been updated to fit the new specification.
C260 R8
SMiT CAM Lock-up issue (Denmark) 1780 R8
DVB-T issue (Denmark): TV2 always stored in channel space nr. 4
* TV2 channel region at room no. 4 is not the same as before the change.
* TV2 located in multiple channel locations, but cannot be displayed.
1727 R9
No subtitles on HD Discovery (Denmark) 1721 R9
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching “Dyrup-Sanderum
Antenneforening”.
C34A R10
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Preventive x xxx 07TV085 SFT 1 2
Remedying x xxx 07TV085 SFT 1 3
2 / 3 07TV085R11
 Install the latest software package using the applicable file attached to this document and following the
abridged procedure for software fixes below.
NOTE: For the full upgrade procedure (panel or board exchange), please refer to TB 07TV086.
 Before upgrading, check Technical Bulletin 07TV101 (“Panel Software Compatibility”) into detail.
Date Panel Software Package Model Attachment Files
March 2010
T2
PKG5.219
KDL-40X3000
KDL-40X3500
C-5219LE_X_40_T2_BCN.ZIP 2.14.591 (Emma)
1.028 (ASUCA)
6.105 (Kaiser)
1.014 (BEM)
KDL-46X3000
KDL-46X3500
C-5219LE_X_46_T2_BCN.ZIP
KDL-52X3500 C-5219LE_X_52_T2_BCN.ZIP
PKG6.216
KDL-40W3000 C-6216LE_W_40_T2_BCN.ZIP 2.14.591 (Emma)
1.028 (ASUCA)
6.105 (Kaiser)
1.014 (BEM)
KDL-46W3000 C-6216LE_W_46_T2_BCN.ZIP
KDL-52W3000 C-6216LE_W_52_T2_BCN.ZIP
PKG5.420 KDL-70X3500 C-5420LE_X_70_T2_BCN.ZIP
2.14.591 (Emma)
1.028 (ASUCA)
6.105 (Kaiser)
1.021 (BEM)
T1
PKG5.316
KDL-40X3000
KDL-40X3500
C-5316LE_X_40_T1_BCN.ZIP 2.14.591 (Emma)
1.028 (ASUCA)
6.105 (Kaiser)
1.014 (BEM)
KDL-46X3000
KDL-46X3500
C-5316LE_X_46_T1_BCN.ZIP
KDL-52X3500 C-5316LE_X_52_T1_BCN.ZIP
PKG6.315 KDL-52W3000 C-6315LE_W_52_T1_BCN.ZIP
2.14.591 (Emma)
1.028 (ASUCA)
6.105 (Kaiser)
1.014 (BEM
07TV085 - Software Packages Follow-Up for FIX-2 Chassis [REVISION 11]
