Автор Тема: 07TV063R1  (Прочитано 206 раз)
07TV063R1
« : 29 Ноября 2023, 17:25:19 »
07TV063R1
KDL-46X2000 TD
Subject IRIS
Caution with Panel and B Board Replacement [REVISION 1]
The WCG1 and WCG3 have different B boards. Since the WCG1 panel is no longer available (refer to Technical
Bulletin 07TV062), this may cause incompatibility problems when replacing.
WCG1 Panel WCG3 Panel
Board Part number Board Part number
B2 COMPL (Service-46-IFP2) A-1223-528-A
B COMPL (Service-46) A-1212-788-A
B2 COMPL (Service-46-IFP2S) A-1212-790-A
1. Panel Replacement
• The table below indicates which panel replacements are allowed.
TO
WCG1 WCG3
WCG1 OK OK FROM WCG3 Not OK OK
• The WCG1 and WCG3 panel can be distinguished by their different picture setting.
Panel Origin
WCG1 INY (Inazawa, Japan) introduction model
WCG3 BCN (Barcelona, Spain) introduction model
• Refer to Technical Bulletin 07TV031R* for the chassis upgrading procedure and 07TV032R* for the model
depending software packages follow-up.
• A software upgrade by memory stick is not sufficient. DEM-NVM data need to be written in advance by a TL3
jig connected to a TV with a crossed flat cable and related code software. For precise DEM-NVM data
handling, refer to Technical Bulletin 07TV064R*.
• The complete upgrading procedure should look as follows:
1. Replace the LCD panel.
2. Write the appropriate DEM-NVM data.
3. Perform a MS-upgrade with the appropriate software package.
4. Perform a fine-adjustment in case of a customer request.
