Автор Тема: 07TV062  (Прочитано 211 раз)
07TV062
« : 29 Ноября 2023, 17:24:10 »
07TV062
KDL-46X2000 TD
Subject IRIS
WCG1 Panel Substitution
The WCG1 Panel is no longer available for service purposes.
• Upon depletion of stock, use the WCG3 Panel instead.
OLD NEW
Description Part number Description Part number
WCG1 (LCD Panel 46inch FHD+TFT) 1-802-159-11 WCG3 (LCD Panel 46inch FHD+TFT) 1-802-159-24
• As a consequence, the “DEM-NVM data” need to be changed in accordance with the new panel type. For the
correct procedure, refer to Technical Bulletin 07TV064, “DEM-NVM Data Reading and Writing by TL3 Jig”.
APPLICABLE SERIAL NUMBERS
Model Destination Serial numbers
UK 7000001~7001371
KDL-46X2000
AEP
7300001~7304200
7304401~7304690
