Автор Тема: 07TV064R2  (Прочитано 373 раз)
07TV064R2
« : 29 Ноября 2023, 17:22:00 »
07TV064R2
KDL-40X2000, KDL-46X2000, KDL-52X2000 TD
Subject IRIS
DEM NVM Data Reading and Writing by TL3 Jig [REVISION 2]
This Technical Bulletin contains the procedure for DEM-NVM data reading and writing with the “TL3 Jig”.
PROCEDURE
1. Requirements
• Pentium III, 130 MHz.
• Available USB port.
• TL3 Jig Interface (9-948-020-98).
• DEM-NVM average data.
• Flat cable (conductors opposite side) (9-913-800-24).
2. Set-up
In the rear cover there is a small removable door that gives access to the service connector. Strengthen the
supplied flat cable by attaching a piece of hard plastic (e.g. from a printed circuit board) to the bottom side. In this
way the rear cover does not need to be removed.
07TV064 - EDID Writing Support [REVISION 7]  - KDL-40X2000, KDL-46X2000, KDL-52X2000
