Автор Тема: 07TV055R1  (Прочитано 191 раз)
07TV055R1
« : 29 Ноября 2023, 17:18:02 »
07TV055R1
KDL-32S2510, KDL-32S2520, KDL-32S2530, KDL-32V2500,
KDL-40S2510, KDL-40S2530, KDL-40V2500, KDL-40W2000,
KDL-46S2510, KDL-46S2530, KDL-46W2000
TD
Subject IRIS
No Audio from SCART on Some Digital Radio Stations [REVISION 1]
The SCART output is muted when listening to certain digital radio stations on “Freeview”, i.e. mono broadcasts.
The output is still present on the speakers and the phone output.
CAUSE
BE software problem.
Update the software of the set, referring to the Technical Bulletins below for the most recent software package and
the correct updating procedure.
Chassis Technical Bulletins Problem solved from below packages and onwards
WAX2F 06TV168R*, 06TV169R* PKG1050E (TM1.024, TD1.010, DM2.15.600)
PKG1051E (TM1.024, TD1.010, DM2.5.511)
WAX2T 06TV170R*, 06TV171R* PKG1128E (TM1.103, TD1.014, DM2.15.600)
PKG1129E (TM1.103, TD1.014, DM2.5.511)
