Автор Тема: 07TV051R10  (Прочитано 344 раз)
07TV051R10
« : 29 Ноября 2023, 16:59:57 »
07TV051R10
WAX-3H Chassis BC
Subject IRIS
Software Packages Follow-Up for WAX-3H Chassis [REVISION 10] 1645
The latest SW package PKG1.301 is valid for the WAX-3H chassis, and solves the problems below.
Issue TB
RGB Picture Distortion with JVC DVD player
07TV052
No picture / no sound with SCM CAM
Scrambled channels (Finland)
Digital banner (France)
HDMI-CEC problems
Technisat CAM
Missing MUX 07TV090
Incorrect characters ä, ö, ü
IRIS code
Pixilation of picture at DVB-T reception (Denmark)
* Frequent pixilation of the image may appear when watching “Dyrup-Sanderum
Antenneforening”.
C34A
CAM lock-up during fast Prog+/- (SMIT CAM, “You see” cable network - Denmark) 6723
EPG Navigation latch-up (Lausanne Citycable provider - Switzerland)
* STBY when navigating through EPG - only recovered by switching off/on main switch. C119
DVB-C missing mux (“Numéricable” network France)
* Several digital services are missing after doing a quick scan in DVB-C. D22A
Missing subtitles for hearing impaired (Denmark)
* No subtitles are displayed when the option subtitles for hearing impaired is selected.
No problem with Basic subtitle options.
D286
Audio description problem
* Yle is using Netherland audio type when sending audio for visually impaired.
When selecting “Audio Description”, Netherland audio appears instead of the correct audio.
1286
TV crash when watching DVB-T (UK)
* The TV set periodically crashes and reboots when watching MUX A (e.g. Channel 5). C722
DVB-T issue (Denmark): TV2 always stored in channel space nr. 4.
* TV2 channel region at room no. 4 is not the same as before the change.
* TV2 located in multiple channel locations, but cannot be displayed.
1727
07TV051 - Software Packages Follow-Up for WAX-3H Chassis [REVISION 10]
