Автор Тема: 07TV037  (Прочитано 225 раз)
07TV037
« : 29 Ноября 2023, 16:54:25 »
07TV037
KLV-V26A10E, KDL-V26A11E, KDL-V26A12U, KLV-V32A10E,
KDL-V32A11E, KDL-V32A12U, KLV-V40A10E, KDL-V40A11E,
KDL-V40A12U, KLV-W40A10E, KDL-W40A11E, KDL-W40A12U
TD
Subject IRIS
Part Number for "Inverter Board"
The "Inverter Board" for the above models has been made available for service purposes.
The correct information for the "Inverter Board" is indicated in the table below.
• In case of a 32" panel, two types of “Inverter Board” are used. Therefore, always check the part number of the
defective board.
• In case of a 40” panel, the two “Inverter Boards” are synchronized. If a problem occurs in one board, replace
both boards by a complete kit.
Panel Size Model S-LCD P/N Inverter Board / Kit P/N
KDL-V26A11E
26" KDL-V26A12U
KLV-V26A10E
/ 1-789-458-11
KDL-V32A11E
32" KDL-V32A12U
KLV-V32A10E
1-789-420-11
1-789-422-11
KDL-V40A11E
KDL-V40A12U
KLV-V40A10E
KDL-W40A11E
KDL-W40A12U
40"
KLV-W40A10E
LJ97-00648A
LJ97-00649A
A-1251-294-A
