Автор Тема: 07TV036R2  (Прочитано 185 раз)
07TV036R2
« : 29 Ноября 2023, 16:53:23 »
07TV036R2
KDL-40W2000, KDL-46W2000 BC
Subject IRIS
Uneven Uniformity [REVISION 2]
Uneven uniformity when the S/W version is lower than PKG1038 (TM1.019, TD1.010, DM2.15.215).
CAUSE
Certain dark viewing conditions, e.g. a blank screen with no video source.
To minimize the problem mentioned above, follow the software upgrade procedure as explained in Technical
Bulletin 06TV168, using the attachments to Technical Bulletin 06TV169R* or 07TV087.
