Автор Тема: 07TV034R7  (Прочитано 305 раз)
07TV034R7
« : 29 Ноября 2023, 16:51:56 »
07TV034R7
KDL-26P2520, KDL-26P2530, KDL-32P2520, KDL-32P2530,
KDL-32U2520, KDL-32U2530, KDL-40P2530
BC
Subject IRIS
Software Packages Follow-up for SE-1T Chassis [REVISION 7]
The latest software package #022 is valid for the SE-1T chassis. It solves the following problems.
Issue IRIS code
DVB-T Issue (Denmark)
* TV skips regional services in Denmark (TV2) due to broadcast changes.
1. TV2 channel is incorrectly stored (Second MUX) – Weaker signal.
2. TV2 is located in multiple channel locations but picture not available.
1727
Horizontal jitter problem in VCR signals (AV connections or RF) F353
Sudden power on problem 1174
Weekly timers problem 1174
Install the latest software package #022 using the files attached to this document and following the abridged
procedure on the next page for software fixes.
NOTE: For the full upgrade procedure (board and panel exchange), please refer to TB 06TV127.
Date SW Package Attachments Data
December 2010 #022
SE1T_922_v2.zip VM 9.22 (Main micro)
SE1T_MS_int_600_3a.zip DM 2.15.600
(Digital micro)
December 2009 / memorystick_wax2p_mheg_int_602.zip
