Автор Тема: 07TV032R3  (Прочитано 359 раз)
07TV032R3
« : 29 Ноября 2023, 16:48:53 »
07TV032R3
FIX Chassis BC
Subject IRIS
Software Packages Follow-Up for FIX Chassis [REVISION 3]
The latest software packages “PKG1021”, “PKG1700”, and “PKG2700” solve the following problems.
Issue TB
Uneven uniformity: only related to sets with PN from list A and C on p.2 of this TB. 07TV033
IRIS Code
OSD change C733
Frame skip problem /
Czechia digital broadcast problem C22A
VHF channel table (Italy): changed frequency list C26X
 Install the latest SW package using the applicable file attached to this document and following the abridged
procedure for software fixes on the next page. For the full upgrade procedure (panel or board exchange),
please refer to TB 07TV031.
 The package to be installed depends on whether the S/N of the set is included in list A, B or C (=> Next page).
Date Package Attachments List Version 40 inch 46 inch 52 inch
January 2009
PKG1700
C-1700LE_40_BCN.zip
C-1700LE_46_BCN.zip
C-1700LE_52_BCN.zip
A
Emma 2.10.413 2.10.413 2.10.413
Kaiser 1.300 1.300 1.300
Wem 5.109 5.109 5.109
Dem 1.020 1.020 2.100
NVM Kaiser 1.060 1.059 1.064
NVM Wem 5.122 5.122 5.122
NVM Dem 1.310 1.910 1.610
PKG2700
C-2700LE_40_BCN.zip
C-2700LE_46_BCN.zip
C-2700LE_52_BCN.zip
B
Emma 2.16.414 2.16.414 2.16.414
PKG1021 C-1021LE_46_BCN.zip C
Emma
2.10.413
Kaiser 1.300
Wem 5.109
Dem 1.020
NVM Kaiser 1.059
NVM Wem 5.123
NVM Dem 1.711
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Preventive x xxx 07TV032 SFT 1 2
Remedying x xxx 07TV032 SFT
07TV032 - Software Packages Follow-Up for FIX Chassis [REVISION 3]
