Автор Тема: 07TV029  (Прочитано 244 раз)
07TV029
« : 29 Ноября 2023, 16:45:06 »
07TV029
KDL-20S2000, KDL-20S2020, KDL-20S2030
BC
Subject
IRIS
Intermittent Power/Control Problems
• Picture OK, but neither the remote commander nor any key button may function, except after powering on again.
• Picture NG and a green led flashing, but neither the remote commander nor any key button may function, except after powering on again.
• The set cannot be powered on after powered off or in standby condition.
CAUSE
Conductive tape on the A2 Board touching the “PWB Via Holes”.
Verify whether at least 2 mm of space is present between the shield tape and the Printed Wire Board. If not, smoothly remove the tape and reposition it further away from the PWB. If the tape has lost its adhesive power, then only replace it by tape with the part number indicated below.
Description
Part number
Tape
4-100-080-21
