Автор Тема: 07TV028R2  (Прочитано 185 раз)
07TV028R2
« : 29 Ноября 2023, 16:44:02 »
07TV028R2
KDL-32S3000, KDL-40D2800, KDL-40S3000, KDL-40S3010 TD
Subject IRIS
Part Number for "Inverter Board" [REVISION 2]
The "Inverter Board" has been made available for service purposes.
The correct information for the "Inverter Board" is indicated in the table below.
IMPORTANT NOTE
Exchanging the "Panel Inverter Board" requires the same reporting as in the case of a panel
replacement. Contact your local Sony Service organization for further details.
SE-1A
Model Inverter Board / Kit
part number
KDL-32S3000 1-789-785-11
KDL-40D2800
KDL-40S3000
KDL-40S3010
1-789-771-11
