Автор Тема: 07TV027R3  (Прочитано 228 раз)
07TV027R3
« : 29 Ноября 2023, 16:42:53 »
07TV027R3
FIX Chassis TD
Subject IRIS
Part Number for "ETC-Inverter MT Board" [REVISION 3]
The "ETC-Inverter MT Board" has been made available for service purposes.
• The part number info for the "ETC-Inverter MT Board" is indicated below.
• The two inverter boards for the 52” panel are synchronized. If a problem occurs in one board, replace both
boards by a complete kit.
IMPORTANT NOTE
Exchanging the Panel Inverter Board requires the same reporting as in the case of a panel
replacement. Contact your local Sony Service organization for further details.
• KDL-40X2000, -46X2000
Model Inverter Board / Kit P/N Board Label
KDL-40X2000
1-789-709-11 LJ97-00819A (ZR2)
1-789-710-11 LJ97-00814A (ZL2)
KDL-46X2000
1-789-627-21 LJ97-00815B (ZL3)
1-789-628-21 LJ97-00816B (ZL4)
1-789-657-21 LJ97-00818B (ZR4)
1-789-659-21 LJ97-00817B (ZR3)
• KDL-52X2000
Panel
Inverter Kit part number
Part number Label
1-802-259-11
1-802-259-12 LT2520HT-LH2-0TR, -0T0, -1T0 A-1251-297-A
1-802-259-13
1-802-259-14 LT2520HT-LH2-2T0, -3T0
A-1251-297-A
A-1251-297-B
=> Check info on next page
1-802-259-15
1-802-259-16
1-802-259-17
LT2520HT-LH2-3T1, -3T2, -4T0 A-1251-297-B
