Автор Тема: 07TV026  (Прочитано 200 раз)
07TV026
« : 29 Ноября 2023, 16:41:44 »
07TV026
KDL-40W2000, KDL-46W2000
TD
Subject
IRIS
Part Number for "Inverter Board"
The "Inverter Board" of these models has been made available for service purposes.
The correct information for the "Inverter Board" is indicated in the table below.
The two “Inverter Boards” for the 46” panel are synchronized. If a problem occurs in one board, replace both boards by a complete kit.
Panel Size
Model
S-LCD P/N
Inverter Board / Kit P/N
40”
KDL-40W2000
1-789-500-11
46”
KDL-46W2000
LJ97-00761B
LJ97-00762B
A-1251-295-B
IMPORTANT NOTE
Exchanging the "Panel Inverter Board" requires the same reporting as in the case of a panel replacement. Contact your local Sony Service organization for further details.
