Автор Тема: 07TV025R1  (Прочитано 194 раз)
07TV025R1
« : 29 Ноября 2023, 16:40:44 »
07TV025R1
KDL-32S2510, KDL-32S2520, KDL32-S2530,
KDL-40S2510, KDL-40S2530, KDL-46S2510, KDL-46S2530,
KDL-32V2500, KDL-40V2500, KDL-46V2500
TD
Subject IRIS
Part Number for "Inverter Board" [REVISION 1]
The "Inverter Board" of these models has been made available for service purposes.
The correct information for the "Inverter Board" is indicated in the table below.
• In case of a 46" panel, two types of “Inverter Board” are used. Therefore, always check the part number of the
defective board.
• The two “Inverter Boards” for the 46” panels are synchronized. If a problem occurs in one board, replace both
boards by a complete kit.
Panel Size Model S-LCD P/N Inverter Board / Kit P/N
KDL-32S2510
KDL-32S2520
KDL-32S2530
AUO 1-789-723-11
32”
KDL-32V2500 / 1-789-658-11
KDL-40V2500 / 1-789-500-11
40” KDL-40S2510
KDL-40S2530
/ 1-789-500-32
LJ97-00761A
LJ97-00762A
A-1251-295-A
46”
KDL-46S2510
KDL-46S2530
KDL-46V2500 LJ97-00761B
LJ97-00762B
A-1251-295-B
