Автор Тема: 07TV022R2  (Прочитано 243 раз)
07TV022R2
« : 29 Ноября 2023, 16:38:07 »
07TV022R2
KDL-40U2000, KDL-40U2530 BC
Subject IRIS
40 Inch Panel Replacement [REVISION 2]
A new, fully compatible version of the 40 inch panel has been registered as a service part.
1. The part numbers for the old and new 40 inch panel are indicated in the table below. Both panels can be
identified by their bar code label.
OLD NEW
Description Part number Description Part number
40” Samsung A3 Panel 1-802-191-11 40” Samsung A4 Panel 1-802-386-11
Samsung A3 Samsung A4
2. Upgrade to the latest software version, using the software attached to Technical Bulletin 08TV020.
3. Write the NVM data according to the panel type with TL3 and Code2 software, using the files indicated below
