Автор Тема: 07TV018  (Прочитано 254 раз)
07TV018
« : 29 Ноября 2023, 16:33:25 »
07TV018
KDL-26S2000, KDL-26S2010, KDL-26S2020, KDL-32S2000, KDL-32S2010, KDL-32S2020, KDL-32S2510, KDL-32S2520, KDL-32S2530, KDL-32V2000, KDL-32V2500, KDL-40S2000, KDL-40S2010, KDL-40V2500, KDL-40W2000, KDL-46S2000, KDL-46S2030, KDL-46S2510, KDL-46S2530, KDL-46V2000, KDL-46V2500, KDL-46W2000
BC
Subject
IRIS
Green Picture with Specific External Equipment
F432
A distorted sync signal may result in a green image via SCART connection.
CAUSE
The RGB output of certain DVD player brands and satellite receivers is not conform to the SCART specification.
Install one of the following software packages, attached to the Technical Bulletins below.
Chassis
SW package
Technical Bulletin
WAX2(C)
PKG1089T
06TV112R*
WAX2F
PKG1035E
06TV169R*
WAX2T
PKG1123E
06TV171R*
NOTE
The symptom does not occur with TV Component input or DVD player output in Composite video instead of RGB.
CHASSIS INFORMATION
Chassis
Models
WAX2
KDL-26S2000, KDL-26S2010, KDL-26S2020, KDL-32S2000, KDL-32S2010, KDL-32S2020, KDL-40S2000, KDL-40S2010, KDL-46S2000, KDL-46S2030
WAX2C
KDL-32V2000, KDL-40V2000, KDL-46V2000
WAX2T
KDL-32S2510, KDL-32S2520, KDL-32S2530, KDL-32V2500, KDL-40S2510, KDL-40S2530, KDL-40V2500, KDL-46S2510, KDL-46S2530, KDL-46V2500
WAX2F
KDL-40W2000, KDL-46W2000
