Автор Тема: 07TV015R4  (Прочитано 342 раз)
07TV015R4
« : 29 Ноября 2023, 16:30:54 »
07TV015R4
KDL-15G2000, KDL-20G2000 BC
Subject IRIS
Software Packages Follow-up for SE1-ODM Chassis [REVISION 4]
The latest software package #19 and #19c are valid for the SE1-ODM chassis (15 or 20"), and include the
improvements below.
Issue IRIS code
DVB-T Issue (Denmark)
* TV skips regional services in Denmark (TV2) due to broadcast changes.
1. TV2 channel is incorrectly stored (Second MUX) – Weaker signal.
2. TV2 is located in multiple channel locations but picture not available.
1727
Audio problem on EPG and Smartlink recordings resolved 1510
Russian language revision 1731
Optimized Russian audio filter 1530
Resolved horizontal jitter problem when playing the VCR (AV or RF connection) F353
Resolved Czech CT2 programme problem C22A
OSD change C733
Install the latest software packages using the files attached to this document and following the abridged procedure
on the next page for software fixes. The software package to be installed depends on whether the S/N is included
in list A or list B.
NOTES
* For the full upgrade procedure (board and panel exchange), please refer to TB 06TV127.
* Check Technical Bulletin 06TV146R on how to write the serial number into the NVM.
07TV015 - Software Packages Follow-up for SE1-ODM Chassis [REVISION 4]
