Автор Тема: 07TV014  (Прочитано 222 раз)
07TV014
« : 29 Ноября 2023, 07:04:25 »
07TV014
KDL-S26A11E, KDL-S32A11E, KDL-S40A11E, KDL-S26A12U, KDL-S32A12U, KDL-S40A12U, KLV-S26A10E, KLV-S32A10E, KLV-S40A10E
BC
Subject
IRIS
Intermittent Picture Blanking with Specific External Equipment
F350
Intermittent picture blanking when connecting a Sky HD Box to the HDMI input. The problem only happens when the resolution is set to “1080i” or “Auto”. The problem does not occur with connections via the Component input.
CAUSE
Compatibility problem with the Sky HD Box.
Replace microcontroller IC1002 on the BE Board as indicated in the table below.
Ref.
Description
Part number
IC1002
ICM27Q401-80K6-WAX1-v14.30
9-948-023-79
