Автор Тема: 07TV013R3  (Прочитано 196 раз)
07TV013R3
« : 29 Ноября 2023, 07:03:19 »
07TV013R3
KDL-32V2000, KDL-40V2000, KDL-46V2000 BC
Subject IRIS
Caution when Replacing LCD Panel [REVISION 3]
LCD panel type WCG3 has been introduced in addition to WCG1.
CAUSE
Different lamp at the backside of the panel.
• Whenever replacing, use the same panel type as long as it is available in repair stock.
• If the original WCG1 panel type is no longer available, the WCG3 type can be used. In that case, make sure to
update with the appropriate software and readjust the W/B, following the guidelines below.
1. WCG1 – WCG3 panel distinction
The information below may help to identify the panel type.
1-1. Serial number
Model Destination
Serial number
WCG1 WCG3
KDL-32V2000
Continental Europe 4300001~4378787 4378788~
UK 4000001~4029133 4029134~
France (MP4) 4800001~ /
KDL-40V2000
Continental Europe 4300001~4339560 4339561~
UK 4000001~4020300 4020301~
KDL-46V2000
UK 4000001~4020300
